How fast can non-turbine jet can goes
Hey guys,
Here is the fast one on video. Many of you had witness the CARF'S Spark I was flying at Ca-Jets.
This is only few non-turbine jets can kept up with turbine aircraft.
Problem with electric going fast use a lot amps and over heat motor. But not this one with TJ100 power plant.
Here is 4 minutes video showing how far electric are coming along.
The flat level speed pass was doing 189mph. Diving speed easy hit way over AMA legal speed limit. Wait a minute. This an EDF.![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
http://www.rcuvideos.com/video/Spark...on-12s-5000mAh
Here is another video done by Jon Barnes over this weeken San Jose Electric Fun Fly-in.
It rain and the event was cancel. But still fun with bunch of guys staying for some flying.
Thanks to Jon and Terry put ltime to capture the video and it was fun watching it.
http://vimeo.com/4455926
Click the bottom of the page to download full version in HD.
You might had to sign up to download.
I know! The power of these electrics is amazing.
Here's another cool electric jet video:
http://www.youtube.com/watch?v=g20kvxJ79Es
The power of that jet in the vertical is amazing, and the cost isn't bad either.
One of these is definitely in my future! Nice, clean, easy, no support equipment....I'm looking forward to it.
Chad
Chad
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (15)
TX
I've been considering electric something for a while, but the cost has always turned me off. Seemed like you would need thousands of dollars in batteries to fly more than once.
It looks like your getting 4-5 minutes flights. How long to recharge? How many sets of batteries do you take to the field?
Price seems reasonable for the spark.
Scott
Scott
![](/forum/images/badges/premium_member.png)
FL
There have been many developements in the electric jet arena lately.
See www.bvmjets.com
On the front page, click on "More C's-More Speed" for the story about BV's demo camo Electra, that went 235 MPH. On the same flight, it had already attained mid 220's.
This is a early kit built Electra....a standard production airframe, with "off the shelf" 40C batteries and EVF unit.
These speeds were documented by the Eagle Tree telemetry system.
See www.bvmjets.com
CA
ORIGINAL: Harley Condra
See www.bvmjets.com
See www.bvmjets.com
I have put hundreds of flights on the spark/TJ100 and it doesn't matter how long I keep the throttle on...it's idiot proof I tell you and trying to keep my eyes on it takes all my attention. The last thing I need to be worried about is "Do I need to back off the throttle?"
The spark sure is a kick in the pants!
Russ
See www.bvmjets.com
See www.bvmjets.com
Harley,
I'm curious about the speed was claim with 40c cell. Someday I'll get to see it myself.
All the Electras I had see flying by BVM reps in California Jets not even close to reach 180 mph level pass. Maybe all this Electra I see still on 30C.
FL
Tam,
Unless you have the ability to clock them (electronically by radar gun, or by telemetry), you are just using the old non-calibrated MA-1, Mod 0 eyeball method.
Don't forget, that when a radar gun is not directly in front of or behind the object being mesasured, the "Cosine Effect" will cause an error, showing a speed slower than the real speed.
An off angle of 25º will show an error of about 10% lower than the actual speed.
Most r5adar guns are accurate to +or- 1MPH.
The 30C Electras have been measured at over 200 MPH.
Tam,
Tam,
Harley,
Distance travel by second is another source to do speed run. Sound also another source.
All you had to do is had the camera set far back. Fly flat level speed for 2 second before the camera and 2 second after the pass the camera.
It not that hard Harley.
Telemetry is not that accurate recording.
It can show the speed during the dive.
Unless you had the GPS and speed sensor are recording accurate.
You can download and see the graphic display speed and altitude over many second frame.
My Feedback: (32)
By the way can you leave the throttle buried for 2 or 3 minutes on that set up
1. The Spark did not make any flat and level speed passes in the videos. They all started from a dive.
2. The Spark did not make any 2 to 3 minute "throttle buried" flights in the videos.
3. Rob Lynch's flight routine with the Electra last in the 6 minute range. The video of Rob's flight had parts edited out because the camera lost track of the plane. (This information is on RCGroups).
4. Rob makes his speed pass at the end of his flight routine when the power from the batteries are at there lowest. Here's a short clip: [link=http://www.flylowandfast.com/Files/Video/Misc/Speed%20Run%20(HD%20720_L).wmv]Rob Lynch End of Flight[/link]
CA
Did I say I held the throttle wide open on the video? No...I fly the spark all the time and can leave as much power on as long as I want. My question was if the Electra/BV fan has a burst throttle setting for high speed passes and needs to let off to save equipment. Again, can it be left full throttle for half the flight or not?
A lot of people are concerned with having to manage power for the sake of the motor and ESC. With the price of all the parts to make these jets go like they do, who wants to be worried about frying an ESC or other electrical part and then have to dead-stick their jet?
Ask Doug about throttle position. He left it burried the whole flight down at California Jets last month! Turbine guys love the spark because you can fly it just like a turbine.
Russ
Russ
My Feedback: (80)
All I have to say is that I flew Tam's entire fleet at Speedworld and CA Jets 2009. The Spark was OFF THE HOOK!!! I was passing up turbine powered jets with ease (Non "Big Block" birds of course). The cool thing about it was that I did not have to pull back the pepper stick at any time. At CA Jets I more than once heard the pilot standing next to me say, "What the hell is that?" I replied, "The electric hair dryer that is passing your ***** up".
I'm not an electric jet owner but if I was I would be installing Tam's setup in whatever I decided to purchase. I have seen other EDF setups with good performance but not awesome troublefree performance of Tam's unit.
2 cents.
Tam,
Are you doubting the speed reading from the telelmtry system?
Tam,
I don't doppler my own planes. I let other want to know how fast it goes and let them doppler it. We just fly it level long enough for good video and sound recording.
BTW, the videos just done for fun fying,
You can't doppler it never does level speed pass long enough to doppler.
ORIGINAL: jetpilot
Tam,
How many battery packs and how long to charge them?
Scott
Tam,
Scott
I got carry with BVM chime in with their Electra speed claim and forget to answer your question.
With the Spark you can do few different set up.
That depend on how fast you want to go.
1. You can just having fun doing 150mph on simple 6s system I got. That is the 30C TP 5000mAh. You can charge it in 35 minutes average with 8.25A charging rate. That is Thunder Power 1010 charger and balancer.
That can do 3-5 minutes flight depend on how long you want to hold the throttle.
2. Next step up is doing 8s system. You need 2 x 4s 5000mAh TP. If you go with this set up. You can get the Hyperion charge and can chare 2 pack at once. This also can charge about 35 minutes.
3. Next step is the 10s set up. This you go with 2 x 5s 5000mAh . Hyperion charger can charge this 5s pack about the same charging time.
4. Now we going with 11s hot set up for speed you see in the video. This need 2 x 4s 5000mAh and 1 x 3s 5000mAh to made 11s set up. You need 2 charger to charge these 3 pack in 35 minutes.
5. Last is the 12s set up. This set up is for the old 25C cell. The 30c cells 11s set up is more than you ever need for the Spark.
Here is what is out there today with Lipos.
There is batteries capable to do 5c charging rate.
If you had 5200mAh 2p pack. You can charge less than 10 minutes. But the problem charger is not available to charge at this rate yet.
Charger only can do 10A max with Thunder Power 1010 and Hyperion. Other charger can also within the same range. But this only two brand I have use.
But my fan system doen't need anything more than 30C. It only draw 100-110A max for high power set up. So the higher C rating doesn't do much for low amps draw fan system. You can use it. But only slight different in performance.
The high C rating cells is good for the fan that draw 130-150A. It need the high C rating to handle it.
Electric do take little understand how to set up your power right.
If you had question. Feel free to call me.
My Feedback: (22)
Great Video Tam!!
Right now the spark is the only plane out there that can hit these speeds, with it's good size,
and cost. At $3000 it's a bargain
Some of the high cost planes are about that for just the plane...
If I drop over $6000 for the higher cost ARFs.. it better come with a playboy bunny for the pit crew![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
you have a real winner on your hands and will introduce many new jets pilots to are world
Great Job
I just hope this thread doesn't turn into mine is faster than your thread..
and you lose the credit that is due for what you have done with your setup
Ron
Great Job
Ron
