Take A look
![](/forum/images/badges/trading_plus_member.png)
ORIGINAL: Jetpilot24
Thats what I thought but I have seen choppers withthe tailpipe out either side so the thrust doesn't rotate it.
I woulden't think you would want it pointing up into the blades but maybe down toward the ground.
the gas flow (it's a gas producer wheel rather then thrust) from the turbine is what drives the heli mechanics power wheel and they in turn have twin outlets just like the turbo prop versions and they aren't made to blow into a bellmouth pipe setup. the above pipe looks like someone made if for a particular purpose (or just hacked up a damaged pipe playing around) and for that you'd have to ask them.
