Lookie what just showed up at my door..
P160SX. Going in my Skymaster F16.
No instructions for the Kerostart and I've never had one. Do you tee off the fuel line into the kero line and use the solenoid valve the same but with kero instead of gas?
AA
AA
My Feedback: (167)
RE: Lookie what just showed up at my door..
There should be a diagram for kero setup in the back of the manual. The diagram probably shows an external plug but the same connections apply to internal plugs.
If you don't have a manual then look on Jetcat's website under tech department...
My Feedback: (10)
Hi Andy,
You can download the latest manual at:
http://www.jetcatusa.com/PDFFiles/In...l%20V6.0J2.pdf
If you look at page 52, just treat the connection to the kerosene ignitor shown in the drawing as the same as the connection to your 3 mm festo on your new turbine.
I have maybe 100 flights on the P-160SX, it is a very nice turbine, I think you will like it, congrats on the purchase.
Any priming issues that I need to know about? The manual that they did send has the Kero Start System (V2) in it. It looks like one could easily flood the turbine with start fluid. Is this less of a problem with the internal start verses the system?
Any pointers would be greatly appreciated.
They are now sending them with Thunderpower 3300 7.4V batteries (20C). I also got the new FOD screen and it looks pretty nice. Fitted for the turbine.
Regarding the P-200, I agree, that would really fly nice in the F-16. But I am saving that one for my big F4 Phantom hehe.
AA
AA
So that is what a new 160SX looks like!! I've had my name on the waiting list for one since last Oct. [:@]
I am flying my 1/6 F-16 with a 160 class turbine (Evo Jet Booster 160) and I think it is a great combo. My P-200 is very happy in the F-4.
My Feedback: (10)
Hi guys,
I cringed when I pulled my P-160SX out of the LA river, that was a nice set up on my BobCat, great turbine and the starts were so smooth, time after time, no worries.
Andy, the main kerosene line (the 4mm) and the burner line (the 3mm) are primed seperately. As Wayne said, when you do the priming, just pull the associated line and direct it into a small container and run the prime till the fuel comes out of the line.
The instructions for both items start on page 52 of the manual (clipped below)
Main fuel feed purge (4 mm line)
1. First remove the 4mm kerosene fuel feed line from the engine and put the end of the tube into a small container. This step is required because the turbine would become flooded with kerosene in the following steps!
2. Fill fuel tank.
3. Connect the GSU to the ECU and select the parameter “Pump TestVolt†or “Purge FuelSystem†in the “Test-Functions†menu. (􀃆 press and hold the button “Menu Select†and use the +/- buttons to scroll until “Test-Functions†is displayed, now release the “menu select†button. Thereafter use the +/- buttons to scroll through the Test-Functions menu until “Pump TestVolt†or “FuelSystem†is displayed).
4. Now press the “Change Value†button to start the fuel pump (use the “Change value†button in connection with the +/- buttons to change the pump voltage/power). Continue pumping fuel until all air bubbles are removed.
5. Re-connect the fuel supply tubing to the engine.
Purge the kerosene ignition system (3mm inlet line)
1. First purge the kerosene main supply tubing (as described above). Fill the fuel tank.
2. Disconnect the 3mm kerosene fuel feed line and put the end of the tube into a container. This step is required because the turbine would become flooded with kerosene in the following steps!
3. Connect the GSU to the ECU and select the parameter â€BurnerValve Test†in the “Test-Functions†menu. (ô€ƒ† press and hold button “Menu Select†and use the +/- buttons to scroll until “Test-Functions†is displayed, now release the “menu select†button. Thereafter use the +/- buttons to scroll through the Test-Functions menu until “BurnerValve Test†is displayed).
4. Now press the “Change Value†button to start the fuel pump on a low power setting to pump kerosene through the kerosene-Igniter tubing (the pump runs on a low power setting, the valve for the Kerosene-Igniter is pulsed On/Off , the main fuel shut-off valve stays closed). Continue pumping fuel until all air bubbles are removed.
5. Re-connect the fuel supply tubing to the Kerosene-Igniter (3mm Festo connector).
2. Fill fuel tank.
Banned
1 Post
Once again we are let down in this hobby. We buy expensive products and dont get comprehensive instructions.............. Shame on Jetcat I say
Dennis
Dennis
The instructions are in the manual you just have to read it, but being men we don't read the instructions until we have broken it.
Mike
EDIT: Kero start is easy and an upgrade compared to gas, a bit like using those new modern radial ply tyers instead of staying on cross ply's, what was good enough for my grandfarther etc:
Mike
My Feedback: (167)
As already stated, the instructions are in the manual. If he does not have the manual for some reason he has been provided a direct link to the on-line manual, and in a very timely manner.
I really don't see the problem...
Man, what a nice product. I installed the Turbine last night and cranked it up for the first time this morning. Fired right up the first time without any problems. The Jetcat is apparently shorter than the Rhino that I had in the F16, so I had to redo the balance. Also, these new Jetcats come with lipo batteries which are lighter than the Lithium Ion.
I went with the new FOD screen. Really nice product that is made for the Jetcat. Much better than using the kitchen sink parts for a FOD screen.
Banned
1 Post
ORIGINAL: Gary Jefferson
Not sure why you feel let down. All you have you know how to do is read the manual. If you don't understand something, just ask and Jetcat reps and others will help.
On line manual assumes that you have internet access............ It may surprise you but not everyone has this. I fly with several people that donot have internet access
My Feedback: (167)
First of all, there is a hard copy manual shipped with every turbine sent by Jetcat. If there was not one with the engine then it is a simple phone call to get one.
Secondly, I only said that Andy (not all of your friends in the UK) had been provided a link to access the manual on-line and I assume that he has internet access since he has made a post on RC Universe.
Its in the manual on page 47. I missed it because its located behind the troubleshooting section as a supplement. See attached. The only thing the supplement missed, unless I missed it somewhere, is that the diagram doesn't show the recommended placement of the petcock valve. I put mine in between the pump and the 3 way fitting to the 4mm and 3mm tubing. Also, there is no mention on how to prime the kero start (3mm tubing) in the manual but Mr. Matts description was correct, which I assume that he got online so all was good! One other thing, I would show the UAT in the diagram for future.
