SKYMASTER 1/5 F86 : Any news ?
Hello,![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Does anybody of you have news from this kit ? Who fly a F86 1/5 Skymaster ?
This is a bit strange to not have news from this nice kit on the forum.
Here, in France, sompe people are a bit worried about the structural strenght of the "18mm carbon" wing pipe.
Thank you
Jean Fi
Thank you
Jean Fi
Hi JeanFi.
An 18 mm carbon rod in itself can take a lot of loads before braking. However 18 mm is thin and under high loads ( 20 kgs at 10 Gs is 200 kgs ) this could act as a blade. The risk would be to see the rod going through the wings. From what I've seen this carbon rod is housed in a thin glass fiber sleeve.
Anton could you show to the concerned people how the wing structure and specifically the female sleeves are made ? Material, thickness etc...
How have the landing gear efforts been modelised ? How are they supposed to transmit to the fuselage structure ? ( fuse points, efforts transmission paths etc... )
How was the structure tested on the long term ? How does the fuselage and spars do after 200 cycles ?
Thanks.
Thanks.
