HELP WITH PROJET HORNET V3 ECU PLEASE
Hi
I have Projet v3 but no manual, the only manual I can find is for the V2
I have had 6 perfect flights and 10-12 starts with this ECU. The version 3 calibrates the pump at every start, during this stage, at the end of the fuel ramp, the engine is shutting down, the ramp produces flames. error message on the GCU reads 'CALIBRATION PLAUSI.FAIL' There is probably a simple fix, but I am lost with no manual.
The supplier is on to this for me, but due to time zones it will take at least 24hrs to get an answer, and I am keen to get the plane loaded to leave for a fly in at the weekend.
RE: HELP WITH PROJET HORNET V3 ECU PLEASE
thanks for the link but that's the V2
I got lucky and found the V3 for anyone who might need it http://www.projet-ecu.de/english/HORNET-III-ENG.pdf
it did not mention 'CALIBRATION PLAUSI.FAIL , but did lead me to turn down the 'pump voltage at start', presto she's perfect.
