JR Matchbox question
I would expect that like pretty much ALL electronics, there are multiple failure modes with multiple consequences. A preset position seems unlikely, but I would expect to see many different possible results ranging from a 'jittering' servo to an undriven servo (no power)
I have a 30% toc extra 260 and I am thinking of putting one on the elevators. Because I think the servos are not working at the same rate and they are off? I have other extras but much smaller and my last big plane was a giles 202. The 30% extra does stuff like flips out of a loop and will dive out of a right turn but not a left turn. Can anybody help????? Thanks Eric
i just put one on my electra for flaps, first time using it seems to work just fine and has many other cool uses. i think if i had the extra channels i would have prefer to do it that way but it's done.
have not had a flight test yet, but I'm sure it will work just fine, if it ever fails i think it will be real easy to figure out what happened
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (40)
I have used JR Matchboxes on a variety of surfaces; elevators, elvons, canards, etc.. and have even used one to drive the four big flaps on my MIBO A-10. Never had a problem with any of them. Concur with Gordon that different failure modes are possible but I have no idea which ones since I have never had a failure of any type.
Craig
Craig
ORIGINAL: giddyuperic
If its the servo, buy two of the same and start over.
Does anybody know what happen in case of a failure, does it freeze the servo in a preset position, a hold position or anything else?
P.S running (NICAD Battery at the time)I guess that would answer your Freezing question.
![](/forum/images/badges/premium_member.png)
My Feedback: (8)
Smart-Flys equalizer II works the same as the matchbox at a fraction of the cost. The main difference is that the Equalizer does not have a case around it.
The operating volts of Equalizer is 4.0 - 7.25 volts
http://smart-fly.com/Products/EqualizerII/equalizer.htm
