propane light off
My Feedback: (12)
TN
I have Wren 54 that I cant get the propane to light off during start sequence. at first I thought maybe I had a dead plug. I removed the plug and grounded it to the case and initiated a start. the plug lit nice and bright as it should. Then I removed the gas line from the thumbscrew and tried using the powermax straight into the turbine. Still no glory. Then I tried blowing into the gas line and although it was a little hard, there was air going into the chamber. Does anybody have a suggestion what I should try next? Im wondering if there is a blockage or something but I can hear gas passing into the chamber[
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (41)
OH
Does the plug coil protrude slightly out of the casing? I had a RAM 500 a few years ago I could not start. Tried everything but after gently extending the coil she started up and never had another starting issue.
Good Luck
Good Luck
My Feedback: (39)
Several questions need to be addressed before we can evaluate this problem.
Is this a new install?
Had the motor always started prior to this?
Any fabricated extensions being used to the starter/glow ?
Onboard propane or direct from a bottle?
Solenoid connected properly? (proper flow direction and properly connected to the ECU)
How many turns c/w on the propane needle?
Location of glow plug (top-side bottom?)
Verify that the solenoid is actually working?
my cell# 260-701-8936
My Feedback: (12)
TN
ORIGINAL: Wren Turbines USA
I also learned to ALWAYS have an extinguisher nearby and to NEVER EVER get complacent with an extinguisher. If I had, I would have had some fire damage for sure!
![](/forum/images/badges/premium_member.png)
My Feedback: (7)
Congrats!!!!! and thank you for been safe by keeping the extinguisher near by, I can't tell you how many guys I have see BBQing their jets just because the extinguisherssssss yes, many, were way far away (including their own) to get them in time to the jet. [:@]
ORIGINAL: Xairflyer
Number one gas related problem, Too Much Gas! most people dont realise how little gas is needed to start these turbines
The hotter the ambient temperature the less propane, has everything to do with propan/oxygen ratio. I use on board and typically dial down to 30 to 35 percent, and a shot of Robart 4 oz tank will last an entire weekend.
Barry
My Feedback: (12)
TN
Bingo! Last time I ran the 54 was early spring. Most likely about 65 or maybe 70 degrees TOPS and humidity not close to what it is this time of year in mid. TN. when it lit off today it was 90 and 80% humidity! It paid off to purge the gas, use the thumbscrew and use VERY little gas. Embarrassing? Well, ya a little. But Im thick skinned so its all good.
As for an extinguisher, if I am even working on a jet with both batts plugged in and switches on I always keep an ext. right there. No exceptions. And no brainer when it comes to even testing an engine. Mostly because its the safety factor involved, murphys laws, and I dont know what it would take for my wife to say yes to replacing something I "cooked"!!!!! If I wasnt prepared I would have baked that sucker good by the time I ran and got it, tried to use it, realised I didnt pull the pin etc......you know how it goes[sm=drowning.gif]
