Reviving old fogies
Decided to blow the dust from a couple of relics, 80's monster beetle and Terra Crusher. Monster Beetle charged up, sprayed motor solvent on MSC, turned on, and out it went going 13-15mph not bad for an old timer. Just have to get close as to make sure it doesn't runaway from me due to the MSC.
As for the Terra Crusher, with a hardly used(less than 1/2 a gallon) 2009 OS.18tz, it fired up after several priming steps, adjusted trasnmission to factory default just to be sure reverse and brakes operates accordingly, reset the bell crank and linkages, reset carb setting high and low needle and idle screw, after all this Crusher idles just fine. However, as I throttle up it does not want to move. My first analysis would be clutch issue. What are your thoughts? I would like to change clutch to the new 3 or 4 clutch shoe design, I know I will more likely have to get a new bell housing with a clutch pinion gear that matches the factory spur gear. I know this is a long shot, I hope somebody have tried this a decade ago or recently.
D3MON (03-03-2020)
i would guess maybe slipper went out, clutch shoes could be bad or slipping, while it was revving up did you notice if the clutchbell was spinning? if so could be something disengages with transmission maybe?
depending on the design of the flywheel of the existing, might be able to utilize a T-Maxx 3-shoe flywheel, (if it is the collet type on yours) or maybe a redcat 3-shoe flywheel (if it uses a "small flywheel" to hold the real flywheel on). redcats shoes are not the best. but you can get upgraded shoes for the flywheel.
i am pretty sure that clutchbell would be 32P, but double check that if possible.
Thanks for the reply! I will provide update on this issue. Hopefully it will help anybody with similar problem.
