what are the must have parts for the warhead
TX
Well ive finnally scraped enough money up to bring the warhead back out of the closet. I ordered a new engine and shes on the way, but my question is what are the must have parts for the warhead? Seemes like every time i would drive it it would break. I know a failsafe unit will be a good investment so i will buy one at LHS. Any other suggestions? Thanks, Casey
YT, BOTSWANA
RE: what are the must have parts for the warhead
That depends. I believe even the first warhead had a few updates to it. So which version do you have? I know they made an EVO update pack, back when i was looking into one. But i ended up getting the RT-X.
CT
hardened pins for the drive shafts and a replacement hardened pin for the top shaft gear (i just used the appropriate sized hardened drill bit and cut to right length) and if it is a warhead then get some lighter weight wheels (i run tmaxx 3.3 wheels and tires) aluminum clutch shoes are nice to have too.
