MIP CVD's
MIP CVD's
I just installed some MIP CVD's on my RC10 GT. How much play should my axles have back and forth through the bearing? It had a little play with the dog bones, but I have enough shims to take it all out of the CVDs. I'm thinking I need some, but how much, if any, do you guys have?
RE: MIP CVD's
I use a feeler guage, I use a paper thin one (a couple thousanths), you can also use a business card. You can also do what they do on losi trucks, put a peice if steel or alluminum tube in between the bearings in the axle carrier, you can crank it down as tight as you want.
RE: MIP CVD's
As long as they don't bottom inside of the differential
outdrive hub, or come close to pulling out of the diff outdrive hub, you're good to go.
