OFFICIAL HPI RUSH / EVO THREAD
#2003
hey, no worries i still have the stock parts for if i have a change of heart, but at the mo i'm liking the alloy and the undertrays are still working a treat!!!!!
#2004
Hi, is this engine any good and how fast would my rush evo go with this engine. thanks
http://www.modelsport.co.uk/?CallFun...ItemID=25929:D
#2005
about engines i put the rs 18 in my evo a few weeks backs even during breaki in my meshing was slightly off and i striped my spur[:@] lucky got a new one as put of my birthday do up evo project
i also put new spings and air filter in and cluch bell
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
#2006
troll dont now exact speed but she fleis
good engine for the price will race mates car some day then ill know
#2007
but if you do get it make shore your gears mesh well and get new mounts and i had to take 3-5mm out of my chassis brace
#2008
GA
That engine is a very good engine and is made by SH. As far as speed there are so many variables and there is no way to say how fast but it should be faster and much better then the stock T-15!
#2009
i agree with 46u ive just run it easy to be safe after run in and its a lot faster than the t15 it even poped little wheelies in my local church carpark they werant on demand witch was unfortunate when the local chavs started bothering me but its probaly good for at least 45 maybe up to 55mph but dont take me up on that im a 15year old with no degree in physics
#2010
thanks i will probly purchase it sometime in the future. How good is it compared to the hpi one? (i will not buy the hpi one anyway because it is too expensive
http://www.modelsport.co.uk/?CallFun...n&ItemID=18182
oh and will i have to buy a different pipe or anything ( i know i have to get engine mounts) thanks
#2011
GA
I am an HPI man and own 4 or their vehicles but am not fond of most of their engines. I do like my K4.6 in my Savage and have a .15SS and they both have been very good. But the T-15 and 18SS I would not buy. SH engines are much better then HPI engines for the most part. I have 6 plus gallons through my K4.6 but big blocks seem to last longer then small blocks.
#2012
dont got the the .18 SS trust me i have it dont get me wrong mine HALLS but i had to do ALOT of moddeing to the engine........ out of the box specs SUCKS i did alot of porting to mine and im very very happy with it right now but when it finally craps out on me i will not be buying a rebuilt kit for it
the .18SS engine was in my rush but i took it out after a crash i had and havent put it back in at the moment i have it in a RS4 2 and let me tell u with the 2 speed gearing i put it in holy crap it FLEW my only issue i kept haveing was at high speed the dam thing keep blowing over!!!! ima put the .18SS back in the rush maybe at the begging of next month since i will be buying the OS .18TZ for the RS4 2 and a starter box
#2013
OH an if any one is intersted here is a video of my savage with the .30 VG in it it was moveing really good i was driveing and filming at the same time so it wasnt the best video!!!
PS ima put a taller gearing when i run more fuel threw the engine at the moment its still a 2speed with a 18/49
http://youtube.com/watch?v=x9h_vXNRg7M
#2014
as far as pipes go i havent brought a new one yet ive bored my header out for more flow and cut it down for more rpm but if you can get one get a new pipe ths or acccosiated are good but some of the more experianced guys may be able to give you more guidence
#2015
GA
Anything is better then the stock composite! For a pipe to work properly it needs to be made of metal and ideal is steal. But there is only one company that makes the out of steal. But aluminum is better then composite or CF. Here is part of an article. All my pipes are aluminum and hope one day to try a steel one.
Why are Fantom tuned pipes made out of steel?. First, steel resonates better than aluminum, which makes the pressure pulses in the pipe stronger, providing for a better “supercharging†effect of the gases being forced back into the combustion chamber. Next, steel holds the heat in a pipe, better than aluminum does. A hotter pipe is more effective in the scavenging process that an engine goes through, or in simple terms, a hotter pipe helps an engine burn fuel more efficiently, ultimately providing you with more horsepower and better fuel mileage. Finally, a steel pipe flat out sounds better than an aluminum pipe. They are more “throaty†and raspier, not to mention their unique factory look and durability sets them apart from all other pipes. If you are concerned about the weight, Fantom pipes only way fractions more than their aluminum counterparts, and in off-road testing there has been no disadvantage from using a steel pipe versus an aluminum one.
#2016
BC, CANADA
Hello, I just bought the hop up diff axle part number 72213 for my rush and it is to big to fit in the diff???? Any suggestions? I already snapped my stock one so I got it for that reason. Everywhere in HPI website says it is for the rush evo and so does that manual.
#2017
GA
OK guys I need some help, I am thinking of selling my Rush and want opinions on what people thing it is worth. I understand I will not even get half what I have in it. Truck is RTR and all you need to run it is charge the receiver pack, batteries for the TX, fuel and a glow plug igniter. I have over $500 just in hop ups and here is a list of most but not all of them. Like I said I am only thinking about it and not sure I will sell. All so check out the pictures. This is the Nitro Rush and has the thicker up dated chassis.
Nitro Rush Hop Ups
Part Number If I known Description Cost +-
HPI 73030 HPI Carbon Fiber front shock tower $21.00
Alloy rear shock tower $11
Alloy rear A arms $15.00
HPI 72180 HPI Alloy rear brace $11.00
HPI 72175 High performance air filter $15.00
HPI A970 HPI tuned pipe and header $73.00
HPI up dated chassis $35.00
HPI 1600 HPI .15SS engine $140.00
Receiver Hump Pack 1100 $15.00
HPI A844 HPI Fiber glass brake disc $13.00
HPI 72525 HPI race fuel tank $14.00
HPI A519 HPI universal dog bones $30.00
HPI A 885 HPI Race clutch $18.00
HPI 72213 HPI heavy duty drive cups $8.00
HPI Titanium turnbuckles $38.00
HPI 72208 Heavy duty middle gear $4.00
Alloy rear knuckles $10.00
HPI 722207 HPI metal heavy duty slipper clutch hub $9.00
Ofna fail safe $20.00
HPI 72190 HPI sway bar kit $17.00
Total of Hop Ups only $517.00
Nitro Rush Hop Ups
#2019
here are also some videos i took of my rush...
http://www.youtube.com/watch?v=ZoiyYTywdw8
http://www.youtube.com/watch?v=4O-R7WCUgnY hope you like!
#2021
already ordered one as a matter of fact![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
and i think you should sell the rush and get something better.... rush looks good tho!
#2022
GA
I have 19 RC cars and trucks right now as I sold some. I have a Savage and HPI MT I race as well as a new Hyper 8 buggy. The reason I am thinking of selling the Rush is I do not run the Rush much and want to put more in to my Hyper 8. I do not race the Rush, as the Rush is not a very good racer.
#2024
46u i knew that hyper 8 was goin to eat up all your atention.............. i think u can get easily 200 bucks if u fleabay it and on a good day maybe 250ish the car is very clean and looks very good if you where to put a BUY IT type of price i would try to go for the 250 bucks.......or better offer.......... well hope this helps!!!! oh and about ur 19 rc's??? how many nitro's do u have?? i know u have like 4 or 5 mini'z (i think) i remeber u showed us ur home track once.......... im just curouse.....
PS tonight ima FINALLY switch out the engine from the RS4 and put it back into its home..........(the rush) and ill be useing it this weekend again for the first time in over 4 months!!!!!!!! wish me luck!!!!!!!
