*~ Official RC10GT2 Thread ~*
#1301
RE: *~ Official RC10GT2 Thread ~*
1.5HP doesn't sound too bad. Are your tires bald?
If you're running on the track, be sure to loosen your slipper clutch, it'll absorb the engine's initial engagement to prevent some wheelspin.
#1303
how many turns out from full-compression is your slipper clutch nut?
EDIT: Wait, you say Dirt Hawgs? That's your reason... Dirt Hawgs are NOT track racing tires, you're not going to get any traction with that type of tire on your local track. Usually, you'd need some type of pin tire... You know, the kind that'll last 10 minutes if you drive it on the pavement.
#1304
MO
right now my slipper is 2 1/2 turns out and i was driving in the grass
yea i know that you use pins on the track but how long do that last cuase tires are about $18 at my LHS
and here is will ill be raceing
http://www.dirtburners.org/Pictures/...5/Default.aspx
#1305
Well, with a properly adjusted and setup slipper and diff, it should last quite some time. Tires are about $18 over here for a pair as well. I know it doesn't sound 'cheap', but in racing, nothing really comes cheap Either bash and have fun with the dirt hawgs on or off the track (no racing), or drop cash on the tires. Just be sure to take 'em off before you go bashing on the pavement again. Don't cheap things out
For pin tires, ask what the local stadium truck racers are using, that's your best bet.
But remember, doing things right is never cheap. And, doing things cheap is never right.
Good luck!
Good luck!
#1306
ORIGINAL: REDisFASTER
Higher RPM doesn't exactly mean that its better. Look at touring .12 engines, they go up to 47,000 RPM, but how come we don't use them? We don't use them because they don't make as much torque in the low-end as offroad-based .12 engines.
The OS .12TZ is a monster of an engine. I'd recommend that one instead.
Eh the .12 TZ is considerably more then what I what to spend. I don't need MONSTER power just something that will do nicely for club racing.
#1307
MO
thanks for the help but one more question will the slide carb work on the gt2 and since it has 1.5 hp will i need to strengthen anything up or can the trans handle it (i wil be racing and bashing (might make a difference))
#1308
ORIGINAL: basherjordan
here is my bone stock GT2.
it finally runs like a champ after i had it tuned by the guy at my LHS.
once it get warmer, im goin to start upgrading some things.
#1309
NC
ORIGINAL: dirty_j_62
hey bryan
do you know of any tracks north of charlotte near va i am about 2 hours north of charlotte in va, strait up 77, and i cant find any tracks around here. the closest one i know of is in king. you wouldnt happen to know of any around mount airy or so would ya?
hey bryan
and then click on community. It will have an area that lists all the tracks as well as a forum for each track.
Link to all the tracks in NC and SC. There is one in Mt Airy if I am not mistaken. Also there is my home track in Lexington, NC.
-bryan
#1313
ORIGINAL: Toki
Does anyone know where i can get all metal gearing for the gt2
ORIGINAL: stasoccerkid
^what motor is that and what header and pipe is that thanks and if i get a .12tz do i have to use a starter box
thanks
thanks
#1315
IN
Any of the TZ engines are gonna give you way more power than you bargained for. TRUST ME.
There is a reason for all that aluminum/titanium on my truck.
OS power ROCKS.
Scott
OS power ROCKS.
Scott
#1316
The .18 TZ? Yes. TZ's are usually the higher-end engines.
For the best-bang for the buck, side exhaust, pull-start powerhouse, the OS .18CV-RX is MORE than enough. All you would need is an NTC3 clutch nut to put on the threaded shaft after you install the flywheel, and you can install the clutch bell. (NTC3 clutch nut is about $5 from Tower)
The .18CV-RX is $110 @ Tower.
#1318
Hey McFly I also have the same shocks as yours but your rear shock bodies seem to have way more thread on them for adjusting. Just wondering if you knew why?
#1319
WA
yeah i am hoping for the power and i am going 18 so i feel the tz is a better choice than the cv. i know the bottem end is going to be crazy. i was hoping someone would know a good spur and bell to get to get the wheels down and a little more top end.i do not race i only bash?
#1320
IN
ORIGINAL: 1FastGT2
Don't know why. They are the shocks that came with the truck.
Scott
#1321
NC
Iam new to nitro rc . Bought a rc10gt2 seems like it handles well . The problem is me friend has a Rustler. It out runs me like I'm sitting still. I have a need for speed . I'm thinking of putting in aa small track in the back yard . (1/2 acre) Any help would be great .
#1322
Well, $110 and $5 can nab you an O.S. .18CV-RX engine an an NTC3 clutch nut (you need it because the 18CV-RX has a short threaded shaft). Its got more than enough power to pounce all over a 3.3 Rustler.
Those prices are from Tower, btw.
#1323
FOR ANY OF YOU THAT ARE INTERESTED IN SOME COOL PICS CHECK OUT MY MYSPACE PROFILE AT MYSPACE.COM/RCACCESORIES. ANY FEEDBACK WOULD BE GREAT.
#1324
MO
what is faster? a firestorm or a gt2? both stock acceleration and top end. i am a basher so i think im going with the firestorm.
#1325
You're asking in a GT2 thread, so about 95% of us will recommend the GT2 for you, for obvious reasons... The GT2 can bash, as well as perform like a monster on the track.
Firestorm... Well... I can't really say anything about the Firestorm
