HELP PLEASE WITH TRANSMISSION
CT
When i turn the car over the car wants to move...would this be a transmission problem?
Im new to this forum and somewhat new to the nitro world
Brian
Brian
WA
RE: HELP PLEASE WITH TRANSMISSION
first whats the car? it shouldn't be your tranny, it most likely your idle, turn that down and that should solve your problem.
CT
Its a HPI nitro mt...currently all taken apart because i needed a new clutch bell and spur gear..
Also the car sat for about 1 year with a half tank of gas...bad?
Thanks, Brian
Thanks, Brian
Yea, this fuel turns into thick oil when it sits for a while. You will need to get that out of the tank and clean your carb and lines to avoid problems. New fuel works well as a solvent.
That would be your clutch engageing and spinning the tires.You probably need to adjust it or get new spings or new clutch,depending on what kind it is
