RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
REVO DUAL BRAKES ON JATO!?
Old 12-17-2008, 06:17 PM
Default REVO DUAL BRAKES ON JATO!?
Does anyone know if the REVO rear brake kit will work on the JATO. Instaed of doing the dual brake upgrade can I just buy this and make it work. An ideas would be greatly appreciated. Here is a pic of it.
Old 12-17-2008, 07:19 PM
Default RE: REVO DUAL BRAKES ON JATO!?
nope wont work.... or so everyone who has tried it in other forums...u can however put duals on it...
u need to brake kits... flip the first cam on backwards on the brake shaft... insert the retainer pin...
then use small machine screws to fasten the other cam onto it.... then just put on pad/disc/pad/disc/pad
works great and gives good response...
also... integy (the only thing they do make good) c/f brake kit... works great..
also ... toss the spring off the linkage and use a cut piece of antenna tube.....
but most importantly.... get the alum brake lever assemble
Old 12-17-2008, 07:24 PM
Thanks alot for the info. I was already looking into getting the aluminum brake lever but the dual brake set up sounds awesome. I will give it a try.
Old 12-17-2008, 07:48 PM
if u need i can get u a link where i guy drew it out in auto cad...
Old 12-17-2008, 08:45 PM
if you could do that it would be great.
Old 12-18-2008, 07:37 AM
http://monster.traxxas.com/showthrea...ght=dual+brake
Old 12-18-2008, 11:48 PM
Thanks alot. Good looking out.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
