Old Hitec Focus 6
Old Hitec Focus 6
I've got an old Hitec Focus 6 and need to know what receiver I can buy to use with it. I plan on using it in a simple park flyer, nothing spectacular but would like the ability to use all channels if possible. Preferably a micro RX to use with micro servos. Also, how do I determine what frequency it operates on as there is no crystal and no other markings/writing to go by. Check out the picture, hopefully someone out there can identify it. Thanks.
RE: Old Hitec Focus 6
ORIGINAL: RC Smasher I've got an old Hitec Focus 6 and need to know what receiver I can buy to use with it. I plan on using it in a simple park flyer, nothing spectacular but would like the ability to use all channels if possible. Preferably a micro RX to use with micro servos. Also, how do I determine what frequency it operates on as there is no crystal and no other markings/writing to go by. Check out the picture, hopefully someone out there can identify it. Thanks.
You may also find one of the above numbers noted on either side of the circuit board.
All current PPM (FM ) url=http://www.hitecrcd.com/receivers/list]Hitec receivers[/url] will work with that TX.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
If you are in a remote location and equipment is expensive or impossible to get, it might be worth using that transmitter. But since you have no info on it and can't even determin its frequency and channel it might be better to buy a new one.
in a package, you can get a 3 channel or 4 channel radio for free.
