servo size help!!!
servo size help!!!
hi,
please help.
what servos to use for elevator and rudder on a 85" SBD dauntless?
how much torque and speed do i need?
is there a calculator to find out these values i will need acording to the surfases?
i am thinking of futaba or hitec.
thanks very much
achilles
please help.
thanks very much
achilles
RE: servo size help!!!
ORIGINAL: rxAxilleas
hi,
please help.
thanks very much
achilles
hi,
please help.
thanks very much
achilles
The MFG usually provides some kind of guidance on servos.
ORIGINAL: rxAxilleas hi, please help. what servos to use for elevator and rudder on a 85" SBD dauntless? how much torque and speed do i need? is there a calculator to find out these values i will need acording to the surfases? i am thinking of futaba or hitec.
thanks very much achilles
Performance Slide Rule Calculator - Servo torque, Horsepower, Stall Speed etc.
R/C Aircraft Proving Grounds - CG, MAC, Servo & Basic Model Calculators
RC Calculators - C.Gadd. [Servo Torque, Wing Loading, Glow to Electric etc.]
RC Performance calculators - Thrust, hp, Airspeed, RPM vs Load. etc
Hitec Current Servo Line-up.
Check each servo for the .pdf of full factory specifications and uses for each servo.
FAQ - Programming digital servos.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
