How to set up flaperson with DX7?
TX
Hi. I recently purchased a DX7 TX and would like to use the flaperons feature on my Venture 60. I have one servo for each aileron. I followed the instructions in the DX7 manual, but I can't seem to get the flaperons to work. If I'm understanding flaperons correctly, I should be able to set DX7 so that when I flip the flaps toggle switch between it's 3 positions the ailerons should move down like flaps according to the percentage of throw I select in the DX7. But when I set up the flaperons, the toggle switch doesn't do anything. The DX7 keeps showing that the flaps are in the "normal" position.
Anyone have any experience using flaperons with a DX7? Tips or a walkthrough?
RE: How to set up flaperson with DX7?
ORIGINAL: foosball_movie
As in the note above did you go and set wing type to FLAPERON?
When you hold the two buttons down and turn on you get model slection,
You then press the two buttons on the left to get to the system menu - that is where you initially select flaperons.
Then press them again to go to the program menus. Drop though until you see the flap system menu. Program flap displacenment to meet your needs. The three position land s/w controls the on/off of the flap
Regards,
Eric.
The big button on the left has two positions. When you turn on to get to the higher level menu you hold the top half down, When you menus select you hold the bottom half down - E.
TX
I was able to get it to work last night. Had to buy a couple of servo extensions in order to plug one into the aileron RX port and the other servo into AUX1.
Works really well now. I'm looking forward to testing it out.
Thanks for the help.
I had the "Auto" turned on under the Flaps Menu. Apparently, this turns off the Flap Toggle switch. That was my problem.
If you connect the servos up the opposite way around as to when you set up the system, two things could happen. You can get reversed ailerons or reversed flaps. If the flaps are reversed you might not notice it untill you are in the air. If the flaps are correct the ailerons could be reversed. Neither is desirable. It is a variable situation because you may also have done some servo reversing to get your desired conditions.
I use a JR lead on one servo and a Futaba lead on the other with matching extension leads. This stops it happening. If your servo leads come out each side you usually dont't see the problem, but if you are messing around inside the fuselge a "switchover" could happen.
Regards,
Eric.
