Single conv.Tx ???Possible?
Hi, Please can you comment on that mail From HiModel PRC,answering a question.I got astonished.Can this be true?Is there such a conversion on Tx?
Quote:
But the Futaba 6EXAP is a single conversion transmitter and does not work with dual conversion, so you need to buy single conversion receiver. For which receiver you should take, it depending on your application. Regards, HiModel
Sincerely Yours,
The HiModel Team
Unquote:
Sincerely Yours,
The HiModel Team
Unquote:
RE: Single conv.Tx ???Possible?
Everything that I have read and that I have seen tells me that there is no such thing as a dual conversion TX. The only thing to note is that if you use this transmitter in PCM mode, you have to use Futaba 1024 PCM RX's and you can not use the more expensive Futaba G3 2048 PCM receivers.
Cheers
Stephen
Cheers
Stephen
The transmitter is the same for either single or dual conversion. The conversion process is a function of the receiver only; completely independent of the transmitter.
Like Rodney says, its a buncha baloney!
If you want an overview of how both work read this http://www.torreypinesgulls.org/radios.htm
