Shaun's 2.2 Comp Rig
OK
Here is an overview of my 2.2 Comp Rig build
Drilling the skid
RC4WD R2D trans test fit
Starting the servo / battery mount, doing BTA steering on it.
Quick mock up, allthread is so I can esilly tune it while building, final links will be made from solid 1/4 inch aluminum rod.
Getting closer on the steering, tierod is for mock up, final tie-rod will be fabbed from 1/8th inch aluminum.
Got the link Geometry figured out.
R2D mounted to skid, with Axiom 55T motor.
Figuring out the shock location.
Made some chassis braces.
Dig servo mount.
Servo mount
Rear links finished
Pretty much finished, minus dig servo.
Drilling the skid
Dig servo mount.
Servo mount
Rear links finished
OK
RE: Shaun's 2.2 Comp Rig
Had to swap in a new ring and pinion today.
Old
New
Old(left) New(right)
My new foam set up I'll be trying this weekend at our 2 day camp 'n' comp.
Sorry for the bad lighting, but here is a pic of the truck assembled.
And ready for the 2 day camp 'n' comp this weekend.
Old
New
Looks real good Shaun! Let us know how you make out this weekend!
Hey what brand/make is your frame? I have one with the same cutout pattern only it is smaller. I am using it on a Cliff Climber, something I acquired in a trade. Looks like the Tibet sun symbol.
-Z
-Z
OK
ORIGINAL: dezfan
Looks good Shawn, the ol' WK has come a long way.
Here's a rundown of the weekend
Day 1, Finished the day with a 88, would have done alot better, but I had two repairs, the first one, I broke the servo mount after a 4 foot drop, and the second repair, I ripped all 4 of the lower link mount screws out of the lower link mounts on the chassis, decided to cut a long peice of all thread and put two lock nuts on either end. Worked great and is still working great, I'll be running it, till I order some Stainless hex button head 3mm screws, that are long enough to go all the way though. Overall I finished 9th for the day out of 15 trucks.
Day 2, Finished the day with a 79, The only problems I had was I popped the yoke off my front drive shaft and instead of just taking a repair, I tried to continue to climb, and took out 3 gates on my way down, and then took a repair. finish 6th, out of 15.
Normally I take upwards of 200 pictures at comps, but my cam died this weekend, so I don't have any.
Looks good man!
I'm pretty sure that chassis is made by KAMAKAZE KUSTOMS. They make a couple different variations of it for different applications.
ORIGINAL: 56-jeephead
Looks real good Shaun! Let us know how you make out this weekend! Hey what brand/make is your frame? I have one with the same cutout pattern only it is smaller. I am using it on a Cliff Climber, something I acquired in a trade. Looks like the Tibet sun symbol. -Z
OK
ORIGINAL: RotaryRush
Looks good man!
Looks good man!
My cam died, but a guy got a picture of my truck for me.
