TT Victoria differences?
Hi all,
Please, can anyone tell me the difference between the Thunder Tiger Victoria yacht and the Victoria II - apart from the different sail colours??
Many thanks,
Many thanks,
I found this on the Howes (UK) site:
Product Name Victoria
Manufacturer Thunder Tiger
Full Description
Description
Command the Sea! With the latest version of the Victoria Yacht. Standing over 4’ tall, Thunder Tiger’s Victoria Yacht is the perfect size for relaxed fun.
Blow-molded ABS hull and deck
Aluminum main mast, boom, rigging line and deck details
Molded keel with ballast installed in the keel bulb
A die cut wood stand is included
One-piece molded hull
High performance tear resist Racing Sails
Specification
Length 779mm
Mast Height 1086mm
Sail Area : 28.6dm2
Beam 197mm
Weight 2.1kg
Seems that the difference is in the keel, but I would want to see one to be sure that the description was accurate.
Full Description
Description
Specification
Length 779mm
Mast Height 1086mm
Sail Area : 28.6dm2
Beam 197mm
Weight 2.1kg
I have built both versions but they both have been given the [link=http://www.okanaganmodelsailboat.org/Step-by-Step.html]OSMA[/link] makeover.
The only difference I remember is the new sails had a sewn in line/pocket in the jib leading edge. (Luff)
