Tamiya Recoil Motor
Tamiya Recoil Motor
I have fitted the Wecohe recoil upgrade to my Tamiya Tiger 1. I have also fitted a smoke unit which drives off the motor to blow smoke when the gun fires. As a result of the extra current used to drive the fan and the new spring I only get about 5 or 6 shots with a new battery, then the moter gets too weak to push the gun back forward. I'm thinking of fitting a stonger motor. This will obviously need to be the same size as the current motor, any ideas?
RE: Tamiya Recoil Motor
I don't know, but wouldn't a stronger motor require more power from the battery? [] Could you put in a better battery pack, instead?
Chad
Chad
you might want to just have a puff of smoke after the gun fires, when the fumes clear the tube and a new round is being loaded. Not much smoke is being generated on actual firing. What you see on firing is mostly dirt/dust etc kicked up from the ground. There is generally a puff of smoke exiting the muzzle pushed out from the new round entering the chamber. That might save a lot of juice.
