Cutting open hatches
ON, CANADA
Cutting out hatches using sewing string.
[link=http://www.youtube.com/watch?v=eb8fRYrq4pA&feature=related]Cutting out Hatches[/link]
I found this on You Tube tonight. Its a great idea that I will have to try.
RE: Cutting open hatches
Common knowledge lol, but I'm sure some people havent seen it. Video is good guide for those who havent tried before
EDIT: safety glasses for using a pin vise is... um... extreme
Thanks for the post. I was wondering how folks keep removing their hatches to relocate the switches. Now, I just need to figure out how they reattach them. Hinges, I assume; but where do they get the tiny hinges from? [>:]
The trick is to use the stock (like the Sherman) molded in hinge. After it is cut out, use the pin vise and a very small hardened bit to drill both hinges with the hatch lid in place, so you only drill one hole straight through.
Depends on the size of the hole that is made. A straight pin is one idea. Leave the 'head' on and cut off what is not needed.
I used my dremmel with a very small drill bit. Works like a router. It will melt the plastic like butter. Very controllable, just remove the slag frequently or it'll get messy as mentioned by speedpro440. Cut the hole slightly undersize, and then use sandpaper or an emery board to finish it off. I've used it to cut out many things on my tanks, and it's alot faster than the thread method.
RE PantherF's hinge method. I have found that it is a might easier to drill out the hinge pin hole before you cut out the hatch. That is, providing that you have adequate mass in the molded hinge (not always so). Also, have used copper wire from telephone jack wiring; insert the stiff copper wire into hinge pin hole (after cutting out the hatch) to get the length, pull it back out, cut to length, peen the ends slightly and drive back in. Most times you don't need it, but CA or body putty on the outside ends of the hinge help hold the wire in place.
That'll work too. [sm=thumbs_up.gif]
Just may have to clean the hole some after the hatch is cut out.
great ideas...thanks.
Make them out of brass sheet and rod.
Is that how you reattached the covers for your charging and switch ports on your Panzer III build? I was looking at recently and like the way you did it. I could see where the cuts were made and that the covers were reattached. But, I could see the mechanism for reattaching the covers and holding them in place.
quote:
ORIGINAL: philipat
ORIGINAL: philipat
