*** What Diffs for Hellfire***
RE: *** What Diffs for Hellfire***
if you need a little bit better diffs go for the hot bodies lightning stadium helical ring and pinion that setup is a little bit stronger
but if you want ultimate strength you can buy cen gst diffs from ebay and install them into the hellfire diff housing
here is a cen diff installed into the hellfire plastic casing. even the drive cups that come with the cen diffs fit the hellfire dogbones fit so you dont need to open the diff to change them THE CEN DIFF MAKES THE GEARING HIGHER APROX SIMILAR TO GETTING A TWO TEETH LARGER CB.
and here is a lightning stadium ring and pinion installed into the hellfire casing. it also has an aluminum diff casing from a savage
i hope this helps
i hope this helps
yes they just drop in but as you see in the picture you need to adjust it with shims. but that is something you should do with all diffs anyway
the hellfire rear driveshaft fits the cen pinion no problem
TN
Cool man thanks a lot I've heared of so many different things and I just needed for someone to tell me exactly what I needed. I just got the truck off ebay used and trying to get all the bugs worked out I got the motor running good the guy had a mach 427 on it that had seen it better day so I went though it and modded it and now its time for the drive trane haha
TN
having trouble finding cen diffs there is some on ebay but they have like 4 days left for bidding know a place that sales them?
FL
ORIGINAL: k20_94_dc
there are two cen diffs on ebay now here is a link to one of them
make sure they look like this
there is another kind that has aluminum casing DO NOT BUY THAT ONE
http://cgi.ebay.com/CEN-Genesis-Nemesis-GST-7-7-Rear-Differential-Diff_W0QQitemZ330318165566QQcmdZViewItemQQptZRadio _Control_Vehicles?hash=item330318165566&_trksid=p3 286.c0.m14&_trkparms=72:1205|66:2|65:12|39:1|240:1 318|301:1|293:1|294:50
