!!HELP!! 8ight-t Servo issues
IN
HI all,
As of today i am trying to put in my electronics on my 8ight-t. i have a 3pk 2.4ghz radio with the futaba R603FS receiver. I am trying to install the servos which are hitecs, throttle is hs-625mg and steering is hs-985mg. i have tried using both 6v and 4.6 volt settings. both servos seem to buzz and glitch a lot and they have a hard time centering. any ideals on this? Both servos are brand new. so is the radio setup
IN
UPDATE: i connected my FM futaba gear and there is no glitching or centering issues. any other suggestions? It seems to me that its a 2.4ghz problem. anyone have anything they can add to this? Could it be a setting in my 3pk radio?
IN
Well, i think i may have fixed it. I was looking around and found this post about having the radio in HRS mode and PPM, PCM modes. I moved it to PPM cause i am not using digital servos, does anyone know if this is correct? seems to have fixed the issue
MB, CANADA
ORIGINAL: mentat
you are 100% correct...and good think you caught it....>HRS WILL BLOW up ANalong servo's and have the possibility of taking out the RX with it....be glad you asked before.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
