good engine for team losi 8ight t 2.0 roller
CA
hey guys I am in the process of building a 8ight t 2.0 and I am wondering what would be a good engine in the 200- 350 dollar range, I run on hot rod hobbies, its fairly open and has a lot of jumps, any recommendations?
RE: good engine for team losi 8ight t 2.0 roller
There are tons of good 21 engines out there.. Go to www.amainhobbies.com and read through the reviews..
ps OS is coming out with a new truggy .25 in the spring..
MB, CANADA
.21 NO questions asked...Newer breed truggy's are geared for race .21's....Not Fuel Hog Torque monster .28's.
CA
If you are serious about racing definately a good .21. They reach a slightly higher RPM than a .28, and if you get it modded, will run circles around any standard enigine or .28. I used my .28 in my old 2.0 T for bashing, but had a modded v-spec for rracing, huge difference.
My Feedback: (8)
ORIGINAL: rcpro31
CO
I would reccomend A: a Mugen JX.21 or you really should contact a member named Supertib on this forum and get a modded Ofna JPX .21. What he can do with the engines is absolutely amazing, and they are fantastic!
OK
RB Killer 9 (K9) or the OFNA equal.. OFNA JLR .21. Same engine as the K9, but costs less. Only difference is cosmetic and the carb.. Under $200 once they hit the shelves..
CA
how is the os v spec 21 thats not modded, It is in my price range.<div>I noticed that there is no clutch assembly on the engine, should i just buy a whole new one or just use one from my other 8t 1.0 rtr engine</div>
CO
I currently run the regular V-Spec in my 8T 2.0, and I love it. It is so easy to tune, and it will hold a tune all day. break in is a pain because it is so tight from the factory, but after that it is smooth sailing. There are a few problems surrounding the conrod, so after break in, you should replace it with the OS Speed rod. This cost $40, but totally worth it. After doing that, the engine is nearly indestructable, and will last for many gallons to come. The regular V-Spec is one of the most powerful .21 engines out there, so it should do well at your track. As for the clutch, I really recommend the Losi steel flywheel, it helps smooth out the engine. The best overall setup is the Dynamite Max-Life clutch shoes with the high endurance 13T cb. I run 4 gold springs, I would also recommend 2 green and 2 gold springs. Below is the exact setup I run:
http://www3.towerhobbies.com/cgi-bin...rodId=LOSA9102
http://losi.com/Products/Features.aspx?ProdId=LOSR8001
http://losi.com/Products/Features.aspx?ProdId=LOSA9103
http://losi.com/Products/Features.aspx?ProdId=LOSA9126
http://www.horizonhobby.com/Products...rodID=DYNP5188
http://losi.com/Products/Features.aspx?ProdId=LOSA9114
http://www3.towerhobbies.com/cgi-bin...&I=LXGPF0&P=ML
Make sure you sign up for the tower #1 Super savers club, costs $10 for a year. It will give you free shipping for the Engine and rod together, plus every month they will send you $60 off coupons for purchases over $300. Hope this helps.
CO
well, your truck should come with everything except the steel flywheel, engine, pipe, and rod. I spent $360 on it as follows:
$240 for engine
$40 for conrod
$60 for pipe
$20 for flywheel
$360 total.
$240 for engine
$40 for conrod
$60 for pipe
$20 for flywheel
$360 total.
CA
sorry, didn't put two and two together. Do you think I could just use my old clutch and replace the shoes and springs?
odonnell super sport 21 is 209 on stormerhobbies.com might be an idea. and you can get JP pipes on ebay for around 25-30 bucks but there used. i bought mine off there and it was about brand new for 20 shipped. just an idea.
CA
Hmm...<div>My dads friend builds machines for o'donnel. he said he could hook me up with something..... is it a good engine?</div>
i have heard nothing but good things about it. i have to get an new engine now and im going to get the odonnell SS21 or the jammin jpx 21. my dad has the jpx and i love it but i think ill be going with the odonnell.
