Top RC Zero from Gator R/C
#1126
darod07 (03-30-2024)
#1128
![](/forum/images/badges/premium_member.png)
I am building a zero. Robart electric retracts with 5in robart wheels. The wheel is interfering with the gear door linkage? The gear door had pre-drilled holes for the control horn. Has anyone else experienced this?
#1129
Just make new hole or try to bend linkage so it's not interfering. I didn't use TopRC solution of closing small flaps, made it servoless similiar as original plane had.
#1131
Sometimes you just have to step away and reevaluate the problem. I was able to dremel the tip off the the gear door linkage and tweak the control rod. All is well now and working as it should.
darod07 (05-03-2024)
#1133
Made some good progress over the last few weeks. Has anyone designed the exhaust tips in CAD? The ones the kit comes with are not so hot. I started working on the design tonight, but don't want to re-invent the wheel! Props to whoever came up with the L brackets on the cooling fins... worked really well! And the cowl mounts to the baffles... really clean....:-)
![](https://cimg7.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_1250_ac64ddc39a704fff8a8a4ca5cf04dcdee44aef5b.jpeg)
![](https://cimg8.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/img_1251_789204f4632012fc6db36d496d77c3d006c80f95.jpeg)
