FokkeRC 1/5 Spitfire MKIX build log
#76
Beautiful work! I’ve followed your build closely on Rumen’s website. I love the metal work and scale detail you’ve added, it’s going to be an awesome spitfire! Thanks for sharing photos.
benoit64 (01-12-2021)
#77
Before heading out to work this week I finished up a rough in of the rudder and elevators, I have some finish sanding to do next. Starting to map out guide-tubes for dual elevator, rudder and tail wheel servos. I’m going to box in the cockpit to make sure I save room for all this. I plan to make it as scale as possible so I think I need to map out the cockpit first I think
. Anyway here’s a few photos of the latest.
#79
Looks great Charlie! Lookin forward to getting up in formation with you this spring!
#83
I began work on running pushrods and mapping out where I want servos to be installed. In doing so, I decided to get the cockpit fitted so I can work all them around it. I was going to just start with the cockpit itself but I was sidetracked working on the pilot seat. I grabbed the actual seat and seat pan from Jiri at JPWarbirds, then decided to mod up the suspension with spare parts and g10 I have around.
raaf (01-20-2021)
#87
[QUOTE=nswords;12658502]I noticed that the spinner has not been cut for the prop. Are you doing that yourself?[.
It has not, I’ve got a retired machinist contact that will cut it. He’s done others for a friend of mine.
#88
A bit more progress on the cockpit today. I was able to route the elevator pushrods around and through the forward sidewalls of the cockpit, I built these from balsa sheeting. I fitted the panel and dropped the pilot in so I could see where I’ll mount the seat. I’ll pull all this out and hold off on details until after I’ve glassed the fuse. Looks like the rudder/tailwheel servo will mount nicely under the seat pan. I’ll get the rear sidewalls and floor in next and once my sheeting arrives I’ll be able to begin skinning the fuse.
#91
Finally got to dive in again, I worked out the rudder/tailwheel servo, and was able to mount it underneath the cockpit seat pan. I’m just waiting on a pull/pull system for the rudder to arrive. The elevator servos will be mounted either side of the forward fuse, being that they won’t be completely hidden by the cowl I’ll need to build an access hatch for each but this design saves some space for sure. I finished up the fit for the rudder and elevator halves and began applying the koverall. I’ll lay some more detail into them and then they’ll need a couple coats of nitrite dope to seal for paint.
I’m at the point I believe I could start skinning the fuse but I’m still awaiting balsa sheeting to arrive, so I began work on the wing. I’ve laid out the right half, cut my carbon spar to length and dry fit the main spar and ribs. Everything is a crisp fit, very satisfied. They’ve supplied cut away tabs on the underside of the outer 2/3 to make it a flat build, nice touch! One thing I may look into modifying are the ailerons, they come with an upper and lower ply template, separated by ribs, which in turn creates a very thick surface, since I’ll be covering these with fliteskin, I may make templates out of thinner ply as to cut down on the thickness.
#96
Right?! My time gets divided up between kids wife work dog annnnnd then rc if there’s any left lol
#98
I was able to get back at it yesterday, between yesterday and today finished up the basic frame up of the wing. Dihedral and incidence are looking good. I finished the shear webbing on the right half and will do the left side next. Then I can begin on the leading edges and tips. The carbon fiber tube is a very snug fit, I think I’ll sand the guide holes a bit to leave some area for hysol when it comes time to bond the halves together. I had to take a couple of photos with the fuse and wing. Awesome seeing it come together!
