RCV.58 low end setting
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (28)
IA
On the low end setting which way do you turn low side screw in or out to richen the mixture. Running very well but have a slight richness on transition motor has about 1and 1/2 gallons of Omega thru it . Starting to run better every flight. Bruce
Hi Bruce
Thanks for your enquiry.
In answer to your question it is a conventional carburettor and works in the same manner. This means you screw in (rotate clockwise) to lean out the mixture or screw out (rotate anticlockwise) to richen the mixture.
I hope this helps. If you have any other queries, don't hesitate to contact me.
Best regards
Laurenne
Best regards
Laurenne
