Spad for a .46LA
RE: Spad for a .46LA
Any of the C class planes, Daggar, Dart but build a RNAF wing OR all 2 mil wing instead of the heavier all 4 mil wing. You're looking at the power output of a 40 pro maybe. I used to fly combat with a TT 40 pro. You couldn't keep in tight furballs but you could pull through once or twice and then had to run out. 46 would make the furball an extended capability.
CA
I think I'm going to build the SNS with a RNAF wing. That oughta do it. The building instructions actually tell you what to do if you have a bushing engine.
