Antique Ultra Sport 60
![](/forum/images/badges/premium_member.png)
I just bought a scratch built Ultra Sport 60 from a pre MAAC member.
Someone built it more than 20 years ago!
Never flown.
Only need servos and radios.
Engine was stuck because of the age. After I put a few drops of nitro, and after a few minutes, it moves very smoothly.
I was going to put it up in my cottage as a decoration.
But after some study, it seems to me that I might be able to get it into sky.
My first question: Is the engine still good after sitting for 20+ years? Engine is brand new, never broken in.
My next question: What size servos I should use? According to the mounting holes, throttle, elevator, rudder are the same size, the aileron is a size bigger.
![](https://cimg6.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1342/img_4879_7ca441009f9f90237cd9a3eeedcdeb3971bcc566.jpg)
Never flown.
![](/forum/images/badges/premium_vendor.png)
My Feedback: (9)
The engine might be ok. The fact that it was stuck tells me it probably had fuel in it once upon a time. If so the bearing will probably go bad quickly. Tiny rust spots on the balls in the bearing will work like sand paper on the bearing cage. I would probably try it if the motor turns smooth. If you do watch for a darker than normal color of exhaust residue. If you see this it's time for new bearings.
Any servo with 50oz or more will work fine on these. I don't know why the aile servo would be bigger unless the builder had two servos mounted side by side. When I built one many years ago I mounted the servos outboard in the wing and did not use the metal torque rods supplied with the kit. It was more a personal choice but it's a setup I like better.
I hope you put is in the air. This was my 4th plane back in the day and I taught me a lot.
David
David
My Feedback: (9)
You can tune with a tach but the pinch method is the easiest. Get it wide open point the nose up 45 degrees and pinch the line for a split second. It should pick up a few rpm or stay the same if it's right. If it slows down it's to lean. It can be to rich doing this but you can usually hear it if it's too rich.
david
david
