competition grade balsa
![](/forum/images/badges/premium_member.png)
Hi
Does any of the UK scratch builders know of a source of competition grade balsa. Or is it a case of doing the best you can with what is available in the UK.
Mike
Mike
It is mainly a case of making do with what we have. If you want to ensure you get the best wood you need to go to the hobby shop and hand pick it.
I buy all my wood from inwood-models.co.uk online. Unfortunately, they dont take the time to sort out different grades and you have to take what you are given. But the upside is that it is a lot cheaper and I normally buy twice as much as I need.
FL
First, you need to know how to grade wood by grain. The weight of the wood doesn't tell you if it's suitable for your purpose. For example, if you choose heavy wood for spars, it may be the wrong grain even though the weight implies that the wood is strong.
If you know how to grade the wood, then take an accurate scale with you to the hobby shop. If each piece of a certain size costs the same as the next, there is no reason not to be greedy and buy the best they have.
![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
FL
Shortman - It's nothing new. Basically learn the difference between A, B and C grain and what it's used for.
I have just the basics about it here, but there are better sources that go into more detail if you search the net a little.
http://www.airfieldmodels.com/balsa.htm
