Go Back  RCU Forums > RC Boats > Speed - RC Gas Boats
Binding a dx2 spectrum transmitter >
Speed - RC Gas Boats Discuss gas RC boats right here!
Old 07-12-2017, 04:46 PM
Default Binding a dx2 spectrum transmitter
I have a dx2. spectrum transmitter with a sr200wp receiver. They came out of bind.I can bind them but servos won't work.I,ve tried to make them work a lot in the last 2 days, but nogo ,any ideas? Is there a different receiver that would be compatible with the dx2.0? I'm kind of stuck on this.Any info would be helpful as I am a noob at this.Thanks in advance ,Bob
Last edited by Justaddwata; 07-13-2017 at 07:46 AM. Reason: Original subject did not relate to subject
Old 07-13-2017, 08:20 AM
Is the rx and trans the same age? or is one dsm and the other dsmx? also have you tried a known good servo? just thoughts to try? I had thisd issue but it ended up the old rx I had wouldn't bind up with my new trans.
Ken
Old 07-13-2017, 03:28 PM
It's all good now wiring was turned around,this is how noobs learn.
Old 07-13-2017, 03:31 PM
Had the wiring turned around,this is how noobs learn.
Old 07-13-2017, 07:27 PM
your very lucky the Red wire stays in the center of the 3 plug wires if things get reversed. puff puff.
Old 07-14-2017, 09:55 AM
Don't feel bad I've done that too....
Old 07-25-2017, 08:08 PM
Ron Olson's Avatar
I had a guy bring me a boat last year that had the same problem. It took me just a second to see the problem. I use the black (negative) wire to the outside as his were swapped around. Things were easier when all of the servos had the tabs on them like the Futaba's so they'd only go in one way. The older Airtronics though messed that up as they swapped the wires around.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
