Prather Commander re-assembly assistance
I'll try to keep this short....Owned a Prather Commander years ago, was stolen - found a NIB one on e-bay a few years back (hobby store found one in the attic after they went out of business) - would run then die after a bit - chased the issue and it ended up being a cooling issue with the engine - replaced engine 260PUM from Bonzi - installed a dual water pump and installed a second pick up......now getting ready to reinstall the fuel lines - I can't remember which line went where on the carb, is there a diagram anywhere? Two lines coming off fuel tank, one for the pick up the other for the 'pump'.
Second question - the 'mesh' material in the tank was degrading so I removed it - where can I buy replacement to help reduce the 'slosh' of the fuel?
I also run a Sonicwake and can appreciate the ease of electric but nothing beats the sound and run time of a gas boat.
Thank you!
Thank you!
