engine kill switch??
what are u guys using for a kill switch. looking for a small waterproof switch, but i cant find. i have a micro switch i want to install in the top of the radio box or engine cover. but cant find a waterproof cover for a micro toggle either. please help. last thig to do.. pics helpful.
dont route the kill switch wire through the radio box the interference caused by the ignition will render your radio useless. always keep any radio component at least 8" away fron the engine. you can use a plastic pushrod too activate the switch, but we set our carb linkage to shut the engine off with the throttle trigger.
of course...but bad habits of hitting the brakes will cause me to keep swiming after the boat. and it has a clutch. i think i got it figured it out. ill post pics soon
