zenoah 26 mod
Banned
GA
Most modders will scribe markings into the case that indicate it was their mod. Its also very easy to see if the intake and exhaust ports have been modded, as well as the transfer ports, crank, and piston.
As far as if you know it makes 6hp or not.... dyno readings are a tool. Its very easy to punch in some numbers and get an inflated HP reading![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
Just like with big motors.... PEAK hp does not mean anything and only win's you dyno contests.
![](/forum/images/badges/trading_plus_member.png)
Your best bet is to buy one from someone with a good reputation. There are a few "big names" in the business who either botch a mod job or or how we would say, exaggerate their RPM and HP claims.
From the outside, look for a different from stock carb and a copper gasket around the base of the cylinder instead of the stock paper one.
![](/forum/images/badges/premium_member.png)
can I trust this website: http://www.easycart.net/whobbies/Engines.html because I see the ez4 with 6hp so cheap I don't know is it 6Hp or the fake one
you can trust whhobies they are well known for quality ,wether they mod a good motor i dont know but ive never heard a bad thing about them as a company to be honest,have you checked out oniel bros and bonzi ?.
hi ive the ez3 here .. carnt comment on the performance as we havent started it yet ..if its anything like my bonzi moded engine its going to screem!
Banned
ORIGINAL: darknet
Banned
GA
ORIGINAL: Ron Olson
Ron... not all engine builders use a copper gasket. Some machine down the jug itself to get a tighter squish while using a stock gasket.
FL
i was just a whouse hobbies 2 days ago. and watched him mod my motor stock 260 pum reved at 12,400 rpms after mods the motor reved at 14,700 rpms he said it was almost 6hp. he uses a stock base gasket and machined down the bottom of the cyclyinde. he also turned down the piston and did a bunch of porting. the motor was dynoed with a bh hanson black widow dry pipe and a 257 carb with 25-1 mixture. i put it in a 50 bonzi. gpsed at 59mph.
Banned
Some stock 260 could output 4hp at 14K rpm, sometimes depends what pipe are you running, I saw a guy toke the pipe off just run the engine with heater only for a minute, wow, the hull was flying...
