Rio 51 1st Impression
NV
Im getting more and more excited about Aquacraft boats, With guys like Grim And Jerry working hard on these boats i fully expect there to be a cat soon, id really like to see a FE cat and Gas cat, only time will tell.
SC
not looking to good Ive been trying to start this thing for 1hr and nothing.. and I am not a newbie to 2cycle motors. Been running 2cycles for years on my 1/5 scale trucks
NV
Choke the crap out of it, pull the plug and pull more to get fuel up top, should spray out a little, also like said above pull the plug and lay it on the motor, try pulling to get a spark..is there a kill switch that might be defective?
CO
is the carb primed to where your finger gets wet by covering the venturi when you pull? If so the only other real option is an electrical/ignition problem.
That dosen't bode well for AQ when the first one someone gets is DOA
![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
NV
Iv seen worse...Aquacraft cant check every motor they get, It should be up to fuji to at the very least make sure the ignition system is running correctly..if thats the case here..might just be a bunk plug, its happened to me. no different then starting a nitro engine to lean and toasting a plug, in my opinion anyways.
SC
Ive tried averything I know I have .. the plug is putting out spark but it doesnt look right to me. like not enough spark. NAPA has orderd me 2 more they will be here tommorow. I will try again tommorow. MY shoulder is in PAIN. like I said I I am no newb to 2cycle .. Everything points to the plug..
Did you follow the starting procedure in the manual?
If not this is what it says.
1. Carefully fill the fuel tank with the appropriate fuel/oil mix.
2. Carefully fill the oil tank with GrimRacer Cable Oil (AQUB9550)
3. Turn on the transmitter and receiver (in that order).
4. Depress the priming bulb until you see fuel enter the clear bulb
5. Remove the spark plug wire form the top of the sparkplug
6. Close the choke and pull the recoil starter briskly 5 times
7. Open the choke and replace the sparkplug wire
8. Open the oil shut off clip
9. Pull the recoil starter to start the motor.
10. If your engine does not start, repeat the starting procedure making sure fuel is in the fuel bulb.
Let me know.
Mike
Let me know.
Mike
hope he gets this thing going[&o],sounds like hes not getting fuel to the plug to me but what do i know
.two very slow pulls after priming and while choking is what i do to start my zen then close the choke(remove thumb) and one sharp short pull at 1/4 throttle and away she goes.before i used that method i had the same shoulder problems as our friend did
.the instuction books not allways right in my experience .
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
SC
well I got it started Finally but it wa runinng like crap. I leaned out the low and top.. 1/4 turn but once I got in it the water it ran maybe 5mins then stalled.. and I cant get it started again. Opps I also Ran some sand paper on the spark plug
and yes Grimracer I followed the instruction to start it.. I am not sure whats wrong yet. BUt I do know my shoulder is killing me
