set up help
VA
well it is a shallow V and has been run either way.... I guess it is matter of choice. this is the hardware it was suggested for this boat...
Banned
GA
Well then its your choice how to mount it.... I run surface drives on my mono's and the stuffing tube comes out of the transom roughly 1/2" above the keel. Determining how high or low you set yours, depends whether you are gonna run it as a surface, sub surface or submerged drive....
