72'' mono - 33MPH first run
Hi everybody.
Well this is my mono.... I have read all the post about this hull ( in small size...)(this is the original size from the plans) and i believe so far im in a good road to make it.
Please if anyone see something wrong, let me know.
Today i put on some of the hardware....
Hardware details:
37cc OKAY Trimmer motor or Honda 51.7cc
SPD III with Dual rudder
Octura X470
The Hull is less then 4 kilos, at the bottom inside are 2 layers of Polyester and all the wood connections with epoxy.
Hardware details:
Octura X470
Boat looks good mate you might want to check Steve Marshalls build out he built his at 54" maybe he can offer a few pointers on how it runs .
mart
[link]http://www.rcuniverse.com/forum/m_6080728/tm.htm[/link]
mart
I have see all the posts of Steve Marshalls 54.....
From there I get some useful info about the build of my mono.....
Tomorrow I will make some photos with the motors and i will post them here with some questions.....maybe i will have answer.
![](/forum/images/badges/trading_plus_member.png)
Hey s2sinner, that's one long boat at 72in, I still have to do alot of playing with mine, I hope the x470 prop will wake it up, Have you had it on the scales yet??. It looks good keep us posted with progress.
Steve
Steve
Hello Steve thanks for the message. Sure is long....Today I try to Install the engine I have some photos all ready but i need to make some spaces on my servers to upload them....I will post another message with some photos.....
About the X470.....What makes you think that is not enough to get it out of the water?
Well here is all the photos....so far...
[link=http://www.showup.ch/alfa]Click here if you can see the photos[/link]
![](http://showup.ch/main/main.php?g2_view=core.DownloadItem&g2_itemId=27&g2_serialNumber=1)
![](http://showup.ch/main/main.php?g2_view=core.DownloadItem&g2_itemId=31&g2_serialNumber=1)
![](http://showup.ch/main/main.php?g2_view=core.DownloadItem&g2_itemId=33&g2_serialNumber=1)
![](http://showup.ch/main/main.php?g2_view=core.DownloadItem&g2_itemId=35&g2_serialNumber=1)
pics look good the motor looks ok give it a try,is that the 50 cc one should push it ok its not as big as i thought.mind you thats a canoe
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
In the pic of the motor, I see a bearing on the clutch housing, did it have a gearbox on it?? was it a overdrive or underdrive.
Steve
Steve
Hello Steve.
Well I know what you mean....
I hope the 470 let the motor run if not i will start play with other props and for sure with another motor.
Was a gearbox there and i take it out.....was 12:1 also that motor have electric starter on but i take it out as well.. ![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
This is the 51.7cc i will test it and we will see how it goes......If is not enough i will try another engine....It is a Canoe....hahahhahahahaha
We will see, after all i believe is the first one of this plans it goes in the water soon....
Today we make the exhaust pipe new and some parts to hold the motor on the hull.....if all is ok Sunday I will make that video i promise...... Bad or Good.
Some details
The motor comes from here [link=http://xingyue.us/product_gd.php?id3=323]Xingyue[/link]
I have another one from Honda and one from Okay ( Husqvarna ) and we will see wich one goes better......
The boat with the motor and drive system so far is 8.3 kilos
Electronics and some other parts needed it make it 8.9 kilos
plus the petrol![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
Also there is a big problem to find parts here in Swtzerland and i have to order them from Internet because i buy the X470 here for 75 USD
So is 3 or 4 times more than the real cost is.
Steve you have try the 470 on your boat yet??? if yes let me know how it goes ( if your motor goes up to the limit of RPM ) thanks
Vassilis
plus the petrol
Vassilis
you might need a bigger porop for that honda motor maybe try a prather 280 or similar,or try one of the ali 78 mm props from here,ive run these and theyre good props but the 78 mm was atad big for my zen so ive reduced the diam,still havent tested that one yet [X(].theres two 78 mm ones mine was the smaller pitch one.the 470 is more for higher rpm motors,i have the x470 on my zen now.
[link]http://stores.ebay.co.uk/Head-of-the-River-RC-specialist_Propellers-Speed-Boat_W0QQcolZ4QQdirZQ2d1QQfsubZ7471302QQftidZ2QQtZ km[/link]
ORIGINAL: martno1fan
I will try it first and then we will see.... To order bigger prop with out test is not a good idea...
Sunday test and then we will see...
I have one question....maybe you can help me with that....
I have one Futaba PL2 with s3003 servos....they are ok for use in the boat or I need something Special
( I mean i can use the s3003 for the garb and something bigger and stronger for the steering.)
Well I try today the boat and all was ok ![Smile](https://www.rcuniverse.com/forum/images/smilies/smile.gif)
I get on GPS 33 MPH the only problem is that the X470 is too small for my engine....
Message for Doug:
The boat is perfect.
With 51.7cc ( made in china.)
Octura X470 the XPD III Drive and 1 liter of petrol comes out of the water easy and is very very stable on running ( with 33 MPH )
even on fast turns.
So im the first one test that (72'') so far.
Sory for no video but I was alone and i cant make it all. I promise that week I will make some videos also for you.
Thanks for the great plans.
Vassilis
![](http://showup.ch/alfa/albums/72/Image%28013%29.jpg)
![](http://showup.ch/alfa/albums/72/normal_Image%28014%29.jpg)
![](http://showup.ch/alfa/albums/72/Image%28015%29.jpg)
![](http://showup.ch/alfa/albums/72/Image%28018%29.jpg)
![](http://showup.ch/alfa/albums/72/Image%28022%29.jpg)
Message for Doug:
even on fast turns.
Vassilis
![](http://showup.ch/alfa/albums/72/Image%28024%29.jpg)
Looking good,i've always fancied a real big boat.Should be good in the open sea.
Still looks quite cold over there in Greece?
Brod..
Brod..
nice one mate she looks good,yep as i said needs that big old prop try the x482 ocyura or prather 280 prop that should get it moving and you could get nearer 40 mph with it
mart
[link]http://bonzisports.com/catalogue/product_info.php?manufacturers_id=&products_id=42[/link]
[link]http://search.stores.ebay.co.uk/rcworldwide-com_prather-280_W0QQfciZQ2d1QQfclZ4QQfsnZrcworldwideQ2dcomQQfs ooZ1QQfsopZ1QQsaselZ97427162QQsofpZ0[/link]
[link]http://search.stores.ebay.co.uk/rcworldwide-com_octura-x482_W0QQfcdZ2QQfciZQ2d1QQfclZ4QQfromZR10QQfsnZrcw orldwideQ2dcomQQfsooZ1QQfsopZ1QQsaselZ97427162QQso fpZ0[/link]
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
mart
