outrigger hydroplane question
1 Post
hello all
i have a quick question
is it atall possable to spray epoxy resin onto a newly built outrigger
my thoughts of doing this was to increase the strengh of the tub and sponsons
would thier be any advantages to doing this
your thoughts would be of great help
thanks guys
thanks guys
RE: outrigger hydroplane question
Hey rogerp1,
Is it a wood hull?
When I made my first outrigger (wood), I thought I needed extra strength so I glassed the outsides with cloth and resin but it added a lot of weight to it and to find out I realy didn't need it. I have since then made another rigger but this time I didn't use and cloth and resin to make the hull stronger. To make the rigger stronger, just add extra pieces of wood to all the joints in the corners.
Use the epoxy to seal the hull after you finish it.
Mark
P.S. I can post some pics if you would like to see.
Is it a wood hull?
Mark
just add strips of cloth to all the seems inside the tub and slow set 3 hr epoxy .seal the outside with 3 hr epoxy using an old credit card,two thin coats should do it.
ORIGINAL: martno1fan
Mark
