lube
TN
Banned
GA
my top choice to use is the blue stuff thats sold at http://www.rcboatparts.com
second choice is Quicksilver 2-4-C with teflon.
I use boating grease from a marine store. It has anti sling & anti corrosion properties & is a lot cheaper than buying the same stuff re-packaged from a hobby shop.
ive never put much thought into it to be honest i just use whatever the local diy store has ,ive been using the same stuff for over two yrs with no problems at all
.Cant even remember what its called oh yea GREASE
Mart
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
Mart
![](/forum/images/badges/trading_plus_member.png)
I've still got some Prather grease plus some of the Grimracer stuff but it smells funny. Also I got some Speed Lube from Mark Sholund that looks and smells more like polsihing compund.
In the basement I've got some of Ed Hughey's grease but after leaving the jar open I noticed that it liked to absorb the moisture in the air turning it brown.
With all of these I can't honestly say that I've seen any advantage to any of them except Grimmie's doesn't throw the grease around.
I use general purpose grease, fresh each run. When I get in, I remove the shaft, give it a rub off, havea look at it. If there is no damage, it goes into storage ina tube containing engine oil. The theory being that the oil penetrates into all the strands and gets into the heart of the cable.
Quick rub off when ready to go, bit of grease and away for the day.
Not had a failure yet.
Glenn
Glenn
Prather prop shaft grease i stocked up a few years ago but getting low now.I have also found various teflon based grease has anyone any experiance with it
Teflon-Fortified Grease
Formulated for the unique and demanding non-hydrodynamic requirements of a bicycle bearing. Race proven by top professionals, on and off-road, since 1988. This super slick grease, coats ball bearings and races, preventing wear and distortion,even inbrutally pounded headsets and bottom brackets. Finish Line’s exclusive thickner prevents oil separation and repels water, even when totally submerged. The exceptional film strength of our synthetic oils will not rupture, even under heavy loads
