Futaba 3PM 2.4 FASST radio
FL
Hi guys: anyone using the Futaba 3PM 2.4 FASST radio system on boats? Need some advise.
Thanks for your time and help!
-Doug.
-Doug.
IL
I have heard only good things about that radio in boats. I personnaly dont have that model but I know people that do.
Paul
Paul
ORIGINAL: DougV
-Doug.
-Doug.
Jerry Dunlap
Futaba Marine Sponsored Racer
FL
You guys running/leaving the rx antenna inside the hull or you need to run it outside the hull?
Reason why I ask is that I use FASST 2.4 on Airplanes/Jets and Helis; I leave the antenna inside the fuselage and it works great!
Doug.
Doug.
![](/forum/images/badges/trading_plus_member.png)
My Feedback: (20)
PA
Its very very short so I think youd be ok, I had an antenna mount so I put mine in it, but its only maybe 2 inches long if that, once it gets through the radio box and out of the hull thats all thats left
I run my antennas through a short tube that exits the radio box. However, on my tunnel boats I place the cowling over the radio box so the antenna is under the cowling.
JD
JD
