K&B 45 parts 7.5
K&B 45 parts 7.5
Anybody run a K&B 45? I I think it is also called a 7.5? Perhaps you can help me with parts identification? I tried in the Glow Engines forum and they were quite helpful but suggested these might be for a marine application.
NV
RE: K&B 45 parts 7.5
You have a backplate with Zimmerman disk valve and venturi, looks like a slightly ground on exhaust and a nose section with crankshaft. what did you want to know?
Do you feel I should list them in the marketplace for a needy member? Are they particularly valuable? I would like them to go to a good home but since I am a disabled veteran I need to sell as opposed to give away. Money is pretty tight right now!
NV
well, if the crank is mint and the nose section has no cracks then id say its worth $40 together, the rear plate with disk and venturi is worth at least $40, the exhaust flange.. $6 to a new home. list them here, its decent parts for a common motor.
