rtr hydro
OR
ORIGINAL: russ722
miss vegas , then go buy a OS .18tz .my buddy has one and right now he got it up to 50.1 mph on the gps.
davey
OH
My friends A-Zracing done a Miss bud with a O.S.18TZ this was video&GPS going at 55MHP that on a proboat too!!!![X(]
The motor was moded.. There doing one up for me to use on my Moded Oberto2 hydro..!
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
NC
ORIGINAL: malicent
vegas all the way lots easier to work on, proboat you need the hands of a ten year old to do any thing to
My Feedback: (15)
VA
ORIGINAL: malicent
yep u got that right tight tight spaces. iv done hacked mine all up. if i did it again defentily a vegas
***Oh the Miss bud is smaller then the vegas also .
My Feedback: (15)
VA
ORIGINAL: d-lo
mind tellin' some specs on that setup? i can't seem to get mine past 43mph......
davey
ORIGINAL: russ722
davey
you have pm
OH
I like my proboat because it looks more real,like the unlimited! Vegas doesnt....[
] Vegas has hull issues too..to thin/flimsey.It's longer then the proboat.I didnt have to hack up my proboat to run a.21 in it.Now the new Oberto is hacked/moded to the tilt lightened up in some areas and has a rear trunk/rear hatch/compartment for a rear wing servo and could put a GPS in there too.Also has working front spoiler too,cut out the windows to put clear windows in it with a mini steve dave in the cockpit..
Has moded sponsons runners with steps and rear ride pads and center V like the real Oberto has.By doing all this might make the boat perform better+go faster with these mods..
Now the new FE unlimited light that grim design looks like a great winner.looks more real,like the unlimited lights.!!! Like to get just a hull too run a nitro motor in that hydro!!
![Embarrassment](https://www.rcuniverse.com/forum/images/smilies/redface.gif)
![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
My Feedback: (40)
MD
was woundering if anyone has put a .32 thundercat 31 motor in one yet and if it would make a difference i have the proboat formula and was going to rip out the .18 and put something bigger in there like .32 cheaper than os fund r tight
OH
has been done but not that fast.. Your better off to get a .21..21 are better and more powerfull then the.32 plus you'll get faster speeds with the .21 then the.32's.
If you want to go with an engine bigger than a .21, go all the way up to a .45 and look at a Sport 40 hull. The catch there is you will probably have to buy the hardware separately, but for higher speeds and a boat that can handle it, that's my recommendation
![](/forum/images/badges/trading_plus_member.png)
KS
ORIGINAL: Hydro Junkie
That thin flimsy hull is part of why a vegas will run circles around the proboats right out of the box [ gee I hope I'm not bashing anybody and get this removed]
OH
LOL!!Ha Ha Ha veryfunny F16man!! There a guy on INTLWATERS moditfiying the vegas hull to make it stronger. But I bet after its done it will weight as much as the proboat or more..Yes the thin hull and better motor beats the proboat.. I'd ran a.18 vegas motor in my proboats and there faster then the.15's...If you put that vegas.18 with a adjustable strut on the pro's it might be different in running in the races alittle bit more tighter in the races.[8D] Going to cut off that nose off of my vegas and put a nose like grims boat has.. It will improve the looks greatly too!![Wink](https://www.rcuniverse.com/forum/images/smilies/wink.gif)
Iwas talking about right out of the box, the only time you are going to have a problem with the vegas is when you hit something, some minor stress cracks after time but no big deal.
My Feedback: (15)
VA
i own the miss bud and my buddys have the miss vegas. vegas is a lil larger and better designed. the proboat is flimsy imop . get a vegas u wont be disapointed.
OH
F16man you forgot the vegas has proublems too.. Heres alist.. Flex couplers are junk,arent turnning true. Fuel tanks are junk,air leaks around the flip lid plus the tank seams like to leak too. Exaust coupler blows out. Radio system are junk are known to glitch. Hulls are thin like to crack around the front cowl. You need to brush epoxy around the motor area to stiffened it up.. If I had to do this over again on getting a hydroboat. I wouldnt touch both of them. I like to proboats for the looks and vegas for the speed.. But would get a better hydro like hydrojunkie said..
