1/12 miss bud modification
hi i just purchased a pro boat miss bud for a good deal only problem is it has a solid shaft. is it possible to convert it to a flex drive and strut and how much fabrication will have to be done
thanx
thanx
MN
RE: 1/12 miss bud modification
Certainly you convert to a flex shaft.... I'm suprised MissHydro hasnt chimed in (I think she has done this before?).... I havnet - but I suggest you do a search on this forum on Miss Bud and you'll find what you wnat - there were a ton of threads on these a couple yrs ago.
Yes u can. I've done it. But my boat is still in drydock for more repairs.
D-lo & Misshydro have done some real good mods to their boats.
U should read their threads, it'll give u some ideas on wat to do.
There are more but these r more recent ones. Pls read through as many
of this threads as possible, they have tons of dos n donts that others have
tried out on dis boats.
Hope dis helps.
Cheers
Hope dis helps.
Cheers
All you need is a complete miss vegas drive , get the pro boat stuff out and install the vegas stuff, the hardest part will be the stuffing tube but with some heat from a soldering iron sould come right out.
OH
I've been alittle bizzy with my Oberto2 and Mopartybobs blackjack..Heres my thread to do a justable strut setup using Miss Vegas adjustable strut,flex cable.rudder..[link]http://www.rcuniverse.com/forum/m_7924686/tm.htm[/link] Here's De-lo thread.If I wouldnt use a alum piece accross the transom. The backend is heavy enought as it.. On My Blue Angel I'll use a piece of carbon fiber accross the transom..It's lighter and stronger..On My Onerto2 I'd made a trunk to get access to the inside to bolt rudder and strut on..Plus re-enforce the transom too.
I thought about changing to a flex shaft for my old straight shaft miss bud, but I ended up leaving it alone. I actually like the straight shaft, it was my first hydro and I hate trying to get the strut height set just right.
OH
its not hard to get the strut hight.. You have better advantages with a adjustable strut..faster speeds..better prop selection to use on it.
thanks alot guys i will definatly be posting pics and checking out those fourms you all were talkin about
thank you
250rwill
thank you
250rwill
OR
here ya go, from head to toe, worked great. although, i had already modded my transom, but all the info is still there...............
good luck!!
davey
good luck!!
davey
