tiger drive for stock miss vegas motor?
anybody know the p# for the tiger drive cover set-up for the stock u-18 miss vegas motor? and will the same bit i use for the rotostart covers work with the tiger drive cover? i just bought my twin sons some redcat monster trucks for xmas and converted them to rotostart before ever wrapping em up, so starting the boat with the same cordless drill set-up would be AWESOME same bit?
OR
RE: tiger drive for stock miss vegas motor?
you really should mod it a bit to work better though, i had one sieze on the start shaft, because it does not protrude far enough into the one way bearing on the aqua engine. i 'pressed' the one way bearing a little further into the gear of the tiger drive, so the start shaft fits farther into it. it now works, but they are tempermental, need to be cleaned, and are a little more maintenance than i like..........
davey
davey
Flood an engine and they're toast also. The gear is only press-fit onto the shaft unless they're finally fixed that problem.
Give me a belt and hand-held starter anytime. The initial cost is more but more worth it to me in the long run.
ORIGINAL: Ron Olson
Using a starting belt(if you have an electric starter) is the only way to go for starting RTR engines. Every one of my MVs has a belt for starting. Once the engine has started, I often will use the pull start because it works fine with a warm engine.
JD
JD
