Antenna routing
Antenna routing
Hi guys, my SE kit did't include an antenna 'tube' (everything else was there except this) so i would like to know if a airplane pushrod guide will work. also can you please post some pics of how you routed your antenna? I'm just waiting for my charger to arrive (astro flight) in about 9 days along with some HS-65s and then i'll be 'up...up an away'...... Thanks...Ice
WI
RE: Antenna routing
Try something like this. Odds are, the T-Rex isn't going to get away from you so far that this would cause a problem. Mine's glitch free in this config.
