confined space flying.....
AK
this is how i know i have it dialed in pretty good. i can fly around all the crap in my garage. im laying tile and setting trim in my house and i decided to hover for a battery. what you cant see is the other tools next to thecamera person. the only prob is the tail is wagging a bit. what causes that?
If you are using the futaba 401 gyro....... The delay is set to high on the gyro or the gain setting in the radio is to high... If you have a digital servo the delay should be at 0... If you have a regular servo (hs56) the delay will be around 60-90 or just turn it down til the wag stops
AK
actually the shutter was only 1/60 of a sec. thats really not that fast at all. it had a iso of 400 and ap was 5.6. the big difference is the flash. i useda large 400 wt with a high speed sync. i do plan on getting a few more in flight shots with the blades perfectly still. its all about the lens and flash. i got a canon 2.8 EF IS lense that will do the trick.
