Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 Can't get the T-Rex 450SE off the ground DX6-Tx and AR6000 Rx >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 10-01-2007, 09:12 PM
Default Can't get the T-Rex 450SE off the ground DX6-Tx and AR6000 Rx
Hi. I have a T-Rex 450SE and i'm trying to get the bird off the ground. I have a DX6 Tx and a AR6000 Rx. I have put the bird up to full throttle and it wouldn't take off...any suggestions ...maybe you can give me the setup that you have and I can try that (pitch settings etc.).
Also, I reverse the servos for the aileron and it reverses just about everything. I would expect the left/right aileron controls would reverse, but it seems like all the servos go nutz when I do...Any suggestions?
-Steve
Old 10-01-2007, 10:54 PM
ArrowNaughtic's Avatar
Default RE: Can't get the T-Rex 450SE off the ground DX6-Tx and AR6000 Rx
You really need to watch Finless bobs videos on helifreak.com. In order to properly set up your TREX you need to get the entire head set up properly and also get your servos working correctly.
Or.................... you go go to this site and follow thier setup too. [link=http://www.digimemphoto.com/guides/backguide.htm]TREX 450SE setup guide[/link]
__________________________________________________ ___________________________________
Of all the things I ever lost....................................... I miss my mind the most!
Old 10-02-2007, 03:44 PM
Swashplate should be set up to 120 degree configuration. With thottle hold on, all three servos should rise when you increase throttle/collective stick. If not, reverse the ones that don't. At full throttle, you should have 10 degree positive pitch. A good 3-point throttle collective setting for beginners is: throttle: 0%, Collective: 0 degrees, throttle 50%, collective 4 degrees, throttle 100%, collective 10 degrees. This will keep your rotor speed up.
Old 10-03-2007, 09:15 AM
ORIGINAL: rlsloan
I would preface this with "at least". I'm running +/- 11 degrees. Also, the cyclic pitch should be at least 6 degrees.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
