Futaba 6EX-PCM Servos
MD
I purchased the Futaba 6EX-PCM, because I did not want to spend the extra money, at the time for the DX7. Now I am pissed. I just had two servo's strip out at the same time. I took apart the servo and the gears are super cheap. Does anyone know if the DX7 servo's are of the same quality? Should I just upgrade the servo's or purchase the DX7?
GA
RE: Futaba 6EX-PCM Servos
which servos and how did they strip??
if you crash a CCPM T-rex... the servos strip...it is part of the game...
you could use Hitec HS-65MG as the gears are a bit stronger.....
MD
Heli: TREX 450SE V2
Servos: S3107
I guess I need to replace the servos. Looking at the gears they look very cheap.
I rolled while spinning up the blades to check balance.
Live and learn.
Servos: S3107
Live and learn.
