Switch for leds on AR7000 Aux2
QC, CANADA
Hi,
I want to connect some white leds to my heli and be able to switch it on/off in flight using the aux2 switch on my DX7.
I checked the leads form the aux2 channel on the AR7000 and I get constant 6V from red/black regardless of the switch positon and something like 0.2-0.4V from yellow and black leads depending of the switch position.
So how can I switch the 6v on and off from the switch? I looked at this (http://www.dimensionengineering.com/PicoSwitch.htm), do I NEED one of those to be able to do what I want?
Is it ok to power my leds from the receiver channel 6v?
NJ
RE: Switch for leds on AR7000 Aux2
As far as i know in order to have lights and be able to turn them on and off you need to things. First you'll need a remote controlled switch (tower sells them)( i think there made by RAM) that you can plug into a free channel. Second you will need a set of lights themselves that you have to wire into the on off switch. Depening on the voltage being put out you may also need a voltage stepdown. Hope this helps
